I have 1990 twin turbo I put a engine in from tiger motorsports. I also purchased the vehicle without a engine. I had to figure some bugs out this forum has helped out alot. Also has a pretty noticeably lifter tick. But I've set the timing btdc 15 degrees an the idle is at 1000 rpm. But Rev just hesitation an drove a short distance an just real sketchy made 8 or 9 psi of boost higher rpm thought it would spool up a little quicker. Also oil pressure kinda on the low side. Any advice would be great almost there to driving shape.
new engine running real rough - jhop198819:31:15 03/01/15
